Removal of a Price Pfister single handle kitchen faucet
Old 03-12-17, 04:29 PM
I have an old Price Pfister, single handle kitchen faucet that I am trying to replace.
The faucet seems to be held in place by a bracket, the shape of a horseshow, with a 2" (or so) nut protruding from it, and the nut has a screw in the middle (no Philips). Please see picture.
The nut and the horseshow are sort of rusted out, so I cannot tell what the nut threads into.
To remove the bracket, which I assume is what will allow me to remove the faucet, do I need to unscrew the nut itself, or the screw in the middle of that nut?
Old 03-12-17, 05:18 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
The nut is hollow and screws onto a threaded extension from the faucet body above. The collar is to spread out the force from the nut. Use either a ratchet wrench of a flat head screw driver to remove.
Old 03-12-17, 07:09 PM
Handyone's Avatar
You can use a nut driver to unscrew the long nut. I've always been able to turn the nut with a 6" crescent wrench. Bend and break off the supply lines if you need to, they will break easily.
