Need help identifying the brand of this shower drain stopper.
Old 03-18-17, 10:25 AM
T
Does anyone know the brand name of this stopper?
Am trying to find a replacement part for the shower tub drain stopper. It's about 1 1/2 inch diameter. See pics.
This stopper does NOT have any screws. Instead, you turn it counter-clock wise to unscrew to open. However, the little PIN is broken and had difficulty opening it but now that's I've opened it, am unable to find similar part online.
Old 03-21-17, 01:57 AM
Bob_Plumb's Avatar
I can't help identify the stopper, but why not take it to a big box hardware store, and go to the tub or drain repair section and find a matching one?
You might want to show it to customer service that you are bringing in a old component before you go wandering through the store.
Old 03-21-17, 02:37 AM
chandler's Avatar
Received 8 Votes on 7 Posts
If you are unable to locate a replacement, you can always remove the strainer in the tub and replace it (properly sealed of course) with a newer one with a pop up stopper. Watco 1.865 in. Overall Diameter x 11.5 Threads x 1.25 in. Foot Actuated Bathtub Closure in Chrome Plated-68305-CP - The Home Depot
Old 03-21-17, 06:44 AM
Handyone's Avatar
Would something like this cover work:
Bath Drain Stopper Quick Cover in Chrome-k826-35pc - The Home Depot
If not I would remove the strainer and replace it like Larry said.
I believe your stopper is called a lift and turn type.
