Replacing kitchen sink sprayer hose
Old 04-01-17, 02:56 PM
T
Hose is leaking under sink when faucet is on. Found out it's coming from where the metal fitting meets the rubber hose where it connects to the faucet. Want to go ahead and replace the hose but not sure how to disconnect from where it hooks into the faucet. It's not a screw on screw off type of connection. Any ideas? Name:  IMG_1301.jpg
Old 04-01-17, 03:12 PM
czizzi's Avatar
Received 14 Votes on 12 Posts
If it is the silver hose, depress the white outermost ring at the same time you are pulling. There may be an o-ring inside that has a flat spot on it and can be replaced inexpensively rather than buying a whole new proprietary hose.
Old 04-01-17, 03:43 PM
T
It's the black hose. I should have specified in my first post. Sorry 😂
Old 04-01-17, 05:36 PM
Handyone's Avatar
Pull out the pin at the top of the plastic branch piece.
Old 04-04-17, 04:18 PM
T
So I need to replace the plastic branch piece too?
Old 04-04-17, 07:27 PM
Handyone's Avatar
Your faucet doesn't look familiar to me. You shouldn't have to replace the plastic piece, there should be no seals inside it.
Pull off the branch and you should see 1 or 2 O-rings on the faucet stem (the male brass or copper part).
Those O-rings can probably be replaced. If you do change them, put a little plumbers grease on the rings.
