Water flooding from the base of the toilet helpp
Old 07-11-17, 04:37 PM
B
Woke up to water throughout my house coming from under the toilet. We are septic. Had the septic drained 6months ago. Water comes out a little when we use the other restroom or shower. Wondering if it could be the pipes clogged or the leech field not working? Any ideas or suggestions would help a lot thanks!
Old 07-11-17, 04:41 PM
XSleeper's Avatar
Received 1,910 Upvotes on 1,716 Posts
Anytime water comes from under the toilet, your wax seal has failed. Yes, it's possible your leech field needs a new branch.
Old 07-12-17, 05:23 AM
P
Received 2,153 Upvotes on 1,928 Posts
It sounds like you have two problems. A clogged drain line or septic problem causing a backup and a failed wax ring allowing the water to escape around the base of the toilet.
