Help! Cannot remove shower handle with no hex screw or cap
Old 08-26-17, 06:02 AM
D
Want to change out cartridge on my shower valve as I'm not getting good hot water flow. There is clearly no hex screw or traditional cap on this handle. Any thoughts? Still trying to figure out how to post picture.
Old 08-26-17, 06:14 AM
There is an insert image icon just to the left of the quotes.
Old 08-26-17, 06:31 AM
D
Photo add
https://www.flickr.com/photos/154137...7685521999200/
Old 08-26-17, 06:39 AM
I see two adjustments in that pic. Try to adjust it before you replace the cartridge.
Old 08-26-17, 07:03 AM
Often times if hot water flow is an issue at multiple taps, the hot outlet nipple on the water heater is plugged with hard build up. You might consider checking that also.
Old 08-26-17, 07:14 AM
D
Thanks. Yes the problem is isolated to just this one faucet. The adjustment screws seem to have helped the situation (thanks for that!). Still a bit frustrating about the not figuring out how to remove the handle....guess that can be a problem for another day.
Old 08-26-17, 09:51 AM
XSleeper's Avatar
Received 667 Votes on 617 Posts
Im guessing that the outer 1/8" - 1/4" is a cap that unscrews if you have a thin rubber mat to cushion your waterpump pliers.
Old 08-26-17, 10:49 AM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
Yes I believe the end cap unscrews... What brand faucet is it?
A simple google search will net you an answer im sure...
Old 08-26-17, 10:53 AM
lawrosa's Avatar
Super Moderator
They are stops to shut the water off...
