Slow drip out of seemingly intentional hole in back of shower assembly
Old 09-05-17, 06:13 AM
The back assembly of the shower, not sure what it's called but where the water lines are directed to the handles in the front, has a drip and the water just drips down into a bed of gravel (tub is on the ground floor). It's a slow drip and the hole isn't a break but rather a smooth circle.
Because the hole seems to have been manufactured as such I don't want to plug it up but at the same time, if this tub were on the top floor we'd have a water leak problem.
Can anyone share insight into this?
(The attached pic doesn't show much but it's the best I could capture given the limited space)
Old 09-05-17, 11:11 AM
steve_gro's Avatar
Received 1 Vote on 1 Post
Hard to tell, but I would guess it's there to accommodate some option that wasn't used. I would turn off the water and take it off to see what's supposed to be sealing it (pipe threads or o-ring) and replace/repair as necessary.
Old 09-05-17, 11:35 AM
The hole itself is smooth and ~1/4" in diameter and unthreaded so it wouldn't appear anything should be there.
I'll run the shower and see if water spurts out.
Regardless I figure the whole system *should* be sealed and I'll get some waterproof tape and see if I can get it in there.
Old 09-05-17, 12:38 PM
Received 1,113 Votes on 1,033 Posts
Trying to locate the hole. Is that piece of furring pointing to it ?
Old 09-05-17, 12:50 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Can you open your picture in Paint and circle the hole and post that here?
Old 09-05-17, 11:57 PM
steve_gro's Avatar
Old 09-06-17, 04:33 AM
I believe I've circled the hole but I remember it's far down there
Old 09-06-17, 06:30 AM
H
Received 95 Votes on 84 Posts
Sounds like somebody tried to hang a picture and hit it with a nail or while drilling a hole.
Old 09-07-17, 05:17 AM
not in that location. the hole is too smooth. also the opposing wall is a closet and the hole would be at the very bottom by the floor.
Old 09-07-17, 09:08 PM
steve_gro's Avatar
There is no reason for an 'intentional' hole in a water pipe that supplies water to a shower mixer.
Since it's near a closet, that may be a reasonable place to open the wall to access it for repairs.
