Gap between grout and tub
Old 09-20-17, 04:53 AM
B
Took out the old caulk and found out there was gap between the grout and tub. What should I do before I recaulk?
Old 09-20-17, 05:15 AM
P
Received 632 Votes on 584 Posts
I would clean the area as best you can. A bleach solution to kill any mold is also a good idea. Then make sure the area is totally clean. I like to wipe down the crack several times with rubbing alcohol. Then caulk.
