New Faucet Sink has very mild warm water, no hot, but the cold works
Old 10-06-17, 06:46 AM
G
Had a new faucet installed recently and now we really do not have hot water to this. Everything on the sink is brand new as we renovated the entire kitchen. Its a Moen, with picture below. ANy help appreciated
Old 10-06-17, 10:04 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
If you didn't install it and it never worked corectly have the installer come back and fix it on his dime. If you paid for it to be done right you shouldn't have to fix it.
Old 10-06-17, 10:06 AM
Handyone's Avatar
That is a quality faucet. The hot water hose might be kinked. Another common problem is an old angle stop valve that might need replaced.
When shutting off the hot water valve below the sink, the washer might have broken up and small pieces are blocking the supply line to the faucet.
I would check that first and try to clear the supply hose.
When reconnecting the supply line, it requires hand tight plus 1/4 turn only, be careful to not overtighten.
Last edited by Handyone; 10-06-17 at 10:09 AM. Reason: agree with Ray, Work should be under warranty
Old 10-06-17, 07:22 PM
I'm not too familiar with the moens but I do know some kitchen faucets have a stop/limiter/scald guard to prevent too hot of water. I know it sounds stupid. If this is the case you should be able to see it by taking the handle off.
Old 10-09-17, 11:03 AM
G
thank you all for the reply. I will try to take the handle off and see if I see anything. I have left a message for the installer
