how to stop water from spraying when disconnecting the snap-on adapter from the
Old 10-11-17, 06:08 PM
F
I have just purchased a portable washing machine that I hook up to my bathroom sink by way of a snap-on adapter.
Whenever I disconnect the intake hose from the faucet the built up water pressure sprays out. Is there a way to prevent this from happening?
Old 10-11-17, 06:18 PM
D
There should be a pressure release button on the back of the adapter.
Old 10-12-17, 02:56 AM
F
I am posting some images to show the type of intake hose connector I have and the faucet is just an adapter I purchased for snap-on hoses. Besides the small tab on the on the connector there isn't anything else. The connector pulls back and then it goes on the faucet piece. Do you have a URL for the type of adapter you are talking about?
https://drive.google.com/file/d/0B_a...F4U0l0UE0/view
https://drive.google.com/file/d/0B_a...1zU0VSVm8/view
https://drive.google.com/file/d/0B_a...lDNjV2SEU/view
https://drive.google.com/file/d/0B_a...AwU3FTV2M/view
Old 10-12-17, 03:34 AM
ray2047's Avatar
Received 13 Votes on 11 Posts
Your pictures are not public. Here is the best way to post pictures: https://www.doityourself.com/forum/l...rt-images.html
Old 10-12-17, 10:31 AM
F
Here are the images I tried posting .
Old 10-12-17, 11:47 AM
Gunguy45's Avatar
Super Moderator
Received 3 Votes on 3 Posts
I'd probably just disconnect it with a washcloth wrapped around it. Seems like it should have some sort of pressure release that vents into the sink though.
Old 10-18-17, 02:26 PM
F
I got a good tip from a YouTube video that was reviewing a portable washing machine. It works. What you do is, and it is a little bit of a bother, turn off the faucet, then turn on the washing machine, as if to do a load of laundry, and it will pull the built-up water from the hose into the washer, then Presto! no more spray bath when disconnecting.
Old 10-18-17, 02:30 PM
D
That crossed my mind but I had second thoughts & didn't post it. Another thought was find an intermediary adapter with a pressure release.
