Delta Porter 3 piece faucet - Can't find ALLEN key for the set screw on the fau
Old 10-12-17, 11:15 PM
This is really teeing me off since the instructions don't even mention the size that I need for the set screw on the bottom of the Delta Porter faucet after paying $150 for it. It just says "you may need an allen wrench", what a joke!
I tried the large and bigger in my set and none of them work! I even had another set and still can't find the size! You think for $150 they could include the proper allen key?? So now I've gotta wait till tomorrow to go to HD and buy another tool!
Old 10-12-17, 11:34 PM
Received 477 Votes on 447 Posts
Can't help you much without the model number of the faucet.
I would think that everything necessary to install it was with it.
Old 10-12-17, 11:36 PM
ray2047's Avatar
Received 13 Votes on 11 Posts
Did you try metric? Your sets may be SAE.
Old 10-12-17, 11:40 PM
It looks like the allen key is only needed to remove the handle. You don't need to remove the handles to install the valves. Don't they get held down with nuts/plates from the bottom ?
home depot/delta/catalog/.pdf
Name:  delta plate.JPG
Old 10-13-17, 06:30 AM
Hmmm, so it's a screwdriver , but I still can't find out what bit it is. I might have to go to HD to check with them.
Old 10-13-17, 07:10 AM
pugsl's Avatar
Received 27 Votes on 26 Posts
If's a Allen wench usually between 1/16 and 3/16
Old 10-13-17, 11:28 AM
Handyone's Avatar
Are you even talking about the handles? That's the only part that uses a hex screw.
If you are trying to tighten the valves from underneath, all you need is a Philips screwdriver, after threading on the brass rings.
Old 10-13-17, 02:13 PM
Guys these were the SET SCREWS that lock the bracket in place against the washer underneath after you hand tighten the brackets. I went to a local hardware and got a 3/32 hex that was like a T tool that would be easier to work with in the upper back of the under sink instead of using a tiny hex wrench.
It was a HEX wrench underneath though. There of course are also hex screws on each of the sides of the faucets up top also, which I didn't have to touch. All done and works great and no leaks!!
Thanks all!
Old 10-13-17, 06:45 PM
Handyone's Avatar
Thanks for the info.... I cannot believe that Delta changed the bottom screws to hex. That is just a real bad idea, they had it perfected and screwed it up.
I've always looked at them as one of the best and easiest to install.
Old 10-14-17, 01:43 AM
Gunguy45's Avatar
Super Moderator
Received 2 Votes on 2 Posts
I'd have probably just replaced them if I had to go buy a new allen wrench. Now if it had been something like a cordless trim router that I needed...that would be different. "Honey I can't believe they changed this and I need to buy another tool...ahhh jeez!"
