Does poop stick to the wax ring when you flush?
Old 11-14-17, 03:24 PM
B
Would poop stick to the wax ring when it goes from the toilet, through the wax ring, into the drain line? Is there a way to prevent it, because poop sticking the the wax ring is not clean.
Old 11-14-17, 03:42 PM
Received 1,610 Votes on 1,482 Posts
Did this one keep you up thinking last night.
The wax ring forms the seal, like a gasket, between the flange and the bottom of the toilet. I'm sure some poop slides by but it's not like you'll have big clumps hanging on.
Old 11-14-17, 07:48 PM
Norm201's Avatar
Received 374 Votes on 339 Posts
This made my day! __________________________________________________________________
Old 11-15-17, 05:35 AM
P
Received 967 Votes on 888 Posts
No, poo and toilet paper doesn't stick to the wax ring even though the wax is sticky. You do want to use the correct wax ring though as using too large a one or stacking two together when it's not needed can cause the wax to squish out into the pipe restricting it's size. In general the wax ring is not the cause of clogs. You are correct though, the wax ring is not clean. It spends it's life being bathed in poo juice but that's it's job to keep all the nasty contained inside the pipe.
Old 11-15-17, 09:02 AM
Marq1's Avatar
Received 537 Votes on 497 Posts
I don't disagree but have always washed my hands after removing/handling an old ring!
Old 11-15-17, 09:46 PM
Gunguy45's Avatar
Super Moderator
Received 4 Votes on 4 Posts
"Does your chewing gum lose its flavor on the bedpost overnight?"
Old 11-16-17, 03:18 AM
Norm201's Avatar
Or do you swallow it in spite!
Old 11-16-17, 03:25 AM
V
Received 1 Vote on 1 Post
Most diligent HomeOwners will routinely inspect the the wax ring at least once a month, and remove anything that has stuck. It's simple preventative maintenance.
Old 11-16-17, 03:33 AM
Norm201's Avatar
OK, what am I missing here? How does one inspect a wax ring routinely? Either it leaks or it does not! In all my life I have never routinely checked a toilet wax ring.
Old 11-16-17, 03:48 AM
Received 429 Votes on 383 Posts
I've never heard of anyone inspecting the wax ring either since the only way to do so would be to pull the commode BUT you should notice if there is moisture puddling around the base of the commode. A quick inspection should make it apparent where that moisture is coming from.
Old 11-16-17, 03:57 AM
V
I've never checked either . . . . but I am not very diligent, and I let matters like this just slide by.
Old 11-16-17, 04:06 AM
Norm201's Avatar
and i let matters like this just slide by.
lol________________________________________________________
