Replacing tub and shower valve assembly
Old 11-15-17, 07:13 AM
D
I need to replace a tub and shower valve assembly in my bathroom (the tub faucet keeps dripping and it seems to be impossible to just repair it). I'm wondering what would be the reasonable price for this job. It involves, of course, opening up the wall behind it... I just got an estimate from a plumber that is way more expensive than what I had expected. Any ballpark figures? Thank you.
Old 11-15-17, 09:06 AM
Handyone's Avatar
Can't really estimate a price. I expect to pay a plumber $160 per hour or more.
A picture would help. Usually the valve stems and washers can be replaced. If you replaced all the washers and the valve still leaks, try seeing if you can replace the valve seats.
Corroded valve seats will let water pass even with new washers. You will need a valve seat wrench and some Teflon pipe dope on the seat threads.
I'm assuming you have a 3 handle valve body.
Old 11-15-17, 09:56 AM
P
Received 620 Votes on 573 Posts
So much depends on where you are located, your house's construction and what faucet you have now and what you are going to for the new one. Which new faucet you pick could swing the installation labor price several hundred dollars or more.
Old 11-15-17, 10:15 AM
D
Here is the picture. I was told to replace the whole valve assembly.
Old 11-15-17, 10:40 AM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
Looks like a delta... If its old ball style stem I see no reason the assembly/cartridge cannot be changed..
In NJ to change the whole valve from behind runs about $900-1200..
The valve itself is $147 without the trim.. I think trim is another $150....
I would put on a moentrol if I were doing it.. If easy access possible knock it down to $700-$800...
https://www.fergusonshowrooms.com/pr...iAAEgL_N_D_BwE
Old 11-15-17, 10:45 AM
Handyone's Avatar
That's not what I pictured but you will be happy with a new valve and trim.
You might want to get three bids and maybe cut out the drywall yourself, anything to make their job easier.
This could be a DIY project with just a few tools and then pay to have the drywall repaired.
Old 11-15-17, 11:00 AM
lawrosa's Avatar
Super Moderator
You have to solder in the wall.. Not user friendly if you never done it before. Fires can start quickly...
Old 11-15-17, 11:07 AM
D
Thanks. I was given an $800 estimate and thought it was way too high, but apparently it may not be.
Old 11-15-17, 11:21 AM
lawrosa's Avatar
Super Moderator
What are they putting in? If its a cheapy I wouldnt go for it... Make sure its a quality unit from the plumbing supply house and not a home store special...
Old 11-15-17, 11:41 AM
P
Has the cartridge been replaced in your existing faucet? If not I would certainly try that first.
Old 11-15-17, 01:51 PM
lawrosa's Avatar
Super Moderator
Here is what I think you have... Watch this video..
https://www.youtube.com/watch?v=SaHUMbUZbHk
Repair kit about 20 bucks...
https://www.homedepot.com/p/Delta-Re...7738/205166198
Old 11-15-17, 08:25 PM
D
Thanks! The problem I have is that we haven't been able to unscrew that dome nut (at about 3:00 into the video). The whole body keeps turning.
Old 11-15-17, 10:22 PM
lawrosa's Avatar
Super Moderator
I would cut the dome off after trying PB blaster...
I would of had it off already....
Old 11-16-17, 05:00 AM
P
First, get the repair kit and a new dome nut. You can contact Delta directly to get the parts if you want. But you will want the parts in hand before you take the faucet apart because you will have to turn the water off to the house before beginning work and you have to have the faucet back together before you can turn the water back on.
Start spraying the dome nut with some penetrating oil a day or two before planning work and repeat the application a few times. You really want it to soak into the threads and make it come off easier.
Turn the water off to the house and open a faucet to relieve the pressure. Then with a large pair of channel lock pliers or a pipe wrench try to get the dome nut off. If it doesn't come off remember that you're in for a $800+ repair. If you can get it off you're out less than $40.
If it absolutely will not budge I start cutting it with a cold chisel and hammer. Starting at the outer most part near the faucet handle I work back towards the threaded end. Once the metal is cut about 2-3 back to the threaded end I pry up one side with a flat blade screw driver. Grab the tab with a pair of Vice Grip pliers and pull/twist to tear the metal all the way back like opening a can of soup. Once it's off the replacement of the guts should go quickly and easily.
Oh, and make sure the tub stopper is down or lay a towel over the drain so little parts don't fall down the drain and disappear.
Old 11-16-17, 09:21 AM
lawrosa's Avatar
Super Moderator
I use a small hand held hacksaw to cut them. I cut a line and split them, but not cutting too deep in the threads underneath..
Usually I apply heat with my torch and they turn no issues...
Old 11-16-17, 11:29 AM
D
Thank you everyone for your advice!
Old 11-16-17, 02:24 PM
P
Do you have a Dremel tool? It can be very useful for cutting off the dome nut.
