How to take off this faucet?
Old 11-29-17, 09:11 PM
B
I have changed like 6 faucets already but I really don't know how to take off this one. I have taken pictures from underneath. It looks very weird, I couldn't find a nut underneath or anything.
Old 11-29-17, 10:33 PM
Received 1,613 Votes on 1,485 Posts
That's a three hole sink. Under the sink...... in the center hole..... is a plate that bridges across the hole with a nut on it.
Old 11-29-17, 10:41 PM
lawrosa's Avatar
Super Moderator
Received 69 Votes on 61 Posts
Take sink off wall and cut it off... Dont waste your time trying to remove it the normal way...
Old 11-30-17, 07:26 AM
Handyone's Avatar
If you don't want to cut it off, I'm pretty sure the nut/threaded rod is removed from the top.
Spray the nut with penetrating oil. The top of the threaded rod should be accessible through the top hole in the spout.
Unscrew it with a hex key wrench (allen wrench).
The valves are unsecured by either removing a thin flat nut or a retaining ring.
Old 12-01-17, 01:44 AM
B
I ended up unscrewing the sprout with hex key from the top hole. Took off the sprout and two handles. The two nuts under the handles actually secured the faucet, I unscrewed the left, the right was corroded so I hard to cut it.
The nut from underneath was very corroded, and I couldn't confirm whether if it was a nut. Anyways u gotta take off this faucet from the top. Will post a pic of the underneath part when I have cleaned it.
Old 12-01-17, 11:01 PM
B
It turns out that there isn't a nut from underneath.
