Toilet valve
Old 12-19-17, 12:45 PM
Geochurchi's Avatar
Received 96 Votes on 89 Posts
Toilet valve
Hi All, Fluid Master fill valve, tank is full,flush toilet and tank won't refill,turn water supply off under toilet then back on ,tank fills and flushes and repeat the same procedure, we replaced the fill valve and everything is fine,we took apart the old and everything was clean , has anyone else experienced this problem?
Geo
Old 12-19-17, 12:49 PM
pugsl's Avatar
Received 76 Votes on 69 Posts
Have never taken one apart but sounds like float was sticking.
Old 12-19-17, 03:30 PM
Norm201's Avatar
Received 374 Votes on 339 Posts
Need a little more info. When you flush, does the water try to fill the tank? Or is there no flow what so ever?
Old 12-19-17, 06:05 PM
Geochurchi's Avatar
No to both.
Geo
Old 12-19-17, 06:35 PM
F
Received 36 Votes on 28 Posts
If the connecting hose is a Watts Flood Safe (or competing brand equivalent) it could be the excess flow valve is weak and shutting off the flow "thinking" it is a large leak. Try closing the supply valve and then just opening it a little to see if it makes a difference. The toilet will fill a lot slower with the valve throttled.
