Pressure Fluctuation in Shower
Old 01-13-18, 09:58 AM
P
Recently Iíve been having water pressure loss or fluctuation in the shower. The pressure loss can be enough to cause resonance noise in the Cu pipes. I have a well and the pressure tank is reading around 42 lbs. The shower has a single knob Kohler diverter valve. I havenít noticed any issues in other faucets.
Does this sound like an issue with the Kohler valve? If so, can anyone point me to a good tutorial for replacing it?
Thanks!
Old 01-13-18, 12:06 PM
P
Received 965 Votes on 886 Posts
Has anything else changed? Did you get a new shower head? It sounds like your hitting a magic flow rate that's causing a resonance. Try removing the shower head and running water like you would for a shower and see if you get the sound.
Old 01-13-18, 02:41 PM
P
Nothing else has changed. The shower head is 5 yrs old. The pressure from the shower head and tub spigot is definitely reduced. The pressure is sporadic however, only getting the resonance noise for a min or so every 3-4 mins.
