Where can I buy this shower plumbing part?
Old 04-08-18, 05:58 AM
I don't know what it is called exactly, but its something like a shower mixer valve. What is correct terminology? The cold water valve side of it is bad. It is extremely difficult to adjust the water temp because if you rotate it a tiny tiny bit, it goes from too hot to too cold. Only after fiddling with it for a while can you get temp just right. before opening up the wall, I thought I would find some separate cold water valve that I could replace, but no, its all one assembly. And to make matters worse, all the parts of this plumbing are soldered together!!
Old 04-08-18, 06:14 AM
A
Received 72 Votes on 65 Posts
It's probably easier than you're imagining. Post a picture of what you have and someone here should be able to help you.
Old 04-08-18, 06:47 AM
XSleeper's Avatar
Received 990 Votes on 901 Posts
You probably just need to replace your shower cartridge. You do that from the handle side of the shower. There are probably a hundred YouTube videos on how to do it, but it depends on the brand and model you have and whether or not you can locate the replacement parts.
