Broken outdoor spigot?
Hi all!
The handle on the spigot from my rain barrel has broken off. The company has sent me a new spigot entirely but in order to install it, I have to empty the barrel, crawl inside and install from the inside! Does anyone have any suggestions on a quick fix that i can do to use the broken off handle or a way to just replace the handle itself?
My guess is that you could remove the remaining piece of the old handle by removing the phillips screw and just slip the new handle over the existing valve stem. Alternatively you could remove the valve bonnet from the broken valve (by using a wrench on the nut below the handle) and replace the bonnet, valve stem and internals into the old valve body - all without having to crawl into the barrel.
If there is a nut inside the barrel, duct tape a crescent wrench handle to a long pipe or board and have a helper keep it vertical while you loosen the outside. That will drain the barrel once you get it off.
It appears that you are able to replace the valve without "climbing in the barrel".
The valve has male pipe threads that would thread into the tank's bulkhead fitting.
Use slip joint water pump pliers to hold the bulkhead fitting right next to the tank wall and unscrew the valve.
Use a pipe thread sealer and don't over-tighten the new valve.
I wonder "why" they sent you a brass valve as a replacement instead of one like that which the barrel was originally equipped with ?
You're probably not the 1st Customer to complain.
I'd just replace the broken plastic handle with the brass handle from the replacement . . . . all you need is a Phillips Screwdriver.
