Leaky bathroom faucet
My shower/tub faucet is leaking quite a bit. I have replaced the spout since the diverter was not operating and I thought this would fix the issue, but it didn’t. I hear water sound coming from the valve trim and when I push the handle further to the left (shut off mode) the sound stops, which leads me to believe that the valve trim is the issue. However, the handle is not loose.
Can someone tell me if replacing the valve trim will fix the leaking or if I have a pipe issue?
Thank you!
Thank you!
Valve trim picture
Pilot Dane,
I hear the water behind the plate and when I turn the handle more to the left, the sound and dripping stops. When I let go of the handle, the sound and leaking starts again.
Thank you.
Thank you.
I would go underneath in either the basement or crawlspace and look for water. You can also remove the knob and escutcheon plate and look inside the wall cavity for a leak.
If you hear water in the wall it's possibly a leak. A leaking faucet does not shut off completely and the tub spout will drip. Hearing water behind "the plate" is possibly a leaking pipe.
