Leaky kitchen faucet (stuck)
Old 09-28-18, 09:16 PM
CluelessOwner's Avatar
Hello everyone,
I'm trying to fix this leaky kitchen faucet but i'm stuck at this part.
I don't know how to remove the circle part to get to the springs and seals of the faucet?
I'm following this video and using the same spanner wrench but it i didn't work. What do i need to do to remove this ??
https://www.youtube.com/watch?v=7UbXmKW-v6o
Thanks
Old 09-28-18, 10:07 PM
Received 3,996 Upvotes on 3,586 Posts
You're watching a Moen faucet repair video but that's a Delta cartridge in your picture. Every faucet is different. Is that a Delta faucet ?
That replacement cartridge is used in 45 different Delta faucets. The big bonnet nut needs to come off. Sometimes it's hand tight and other times it needs help. Usually a large pair of channellock pliers is helpful but you need to protect the nut from the teeth of the pliers. A rag or a piece of rubber works well. Once that big nut is off you can remove the internal nut and then..... the cartridge pulls straight out.
This video is for a bathroom faucet but the repair method is identical to your kitchen faucet.
youtube/watch?v=1Q0PmvTk7os
Replacement cartridge.....
Brasscraft part # Sld1056 D
Delta part # RP50587
Old 09-29-18, 02:57 PM
@PJmax You were right. It is a delta faucet.
I'm stuck at this part now. The brass ring ? is not budging at all
Old 09-29-18, 04:36 PM
B
Received 304 Upvotes on 269 Posts
Use an adjustable wrench on the flats of the brass hex nut. Turn CCW for removal and CW for install.
Old 09-30-18, 12:37 PM
Smile
Thank you guys! I got it to work. The channel lock pliers that I was using wasn't big enough. I bought a bigger one and it worked!
Thank you very much for the help!!
$29 for the cartridge and $9 for the channel lock pliers
