Grohe? Temperature Control removal or adjustment
Old 01-07-19, 04:03 PM
I have been researching this mystery for over a week, hardly sleeping and unable to shower. I have what I think is a Grohe thermostatic temperature mixer that only provides water at 95 degrees farenheit. I have been able to remove a few easy parts of the handle that screwed right off but I am stumped at the black plastic temperature indicator part of the handle. This part has a white plastic safety stop button in-set in the handle. How do I remove this part to make a water temperature adjustment and to clean this valve? It doesn't seem to want to screw off and I don't see any set screws anywhere.
Old 01-07-19, 10:50 PM
steve_gro's Avatar
Received 1 Vote on 1 Post
While I'm not sure how that piece comes off, I do know that there should be a button in the trim that you can push to turn past that point and get hotter water. I think you can blame the BAR for making so many lawyers for this one.
If you still need it off, you can call Grohe at 800-444-7643.
Old 09-14-19, 09:57 AM
R
Angry were you able to fix it?
I have same thing and my shower water is not hot enough. were you able to fix it ?
