Remove shower glass from u-channel
Old 03-13-19, 12:18 AM
H
Question Remove shower glass from u-channel
Hi everyone, I've been searching the forum for this but haven't found anything so I thought I'd post this in a new thread. I'm trying to remove a frameless shower glass assembly. One step that I'm not sure how to tackle is removing the glass from the u-channel. Can anybody give me some advice? See attached photo of the shower.
Thanks!
Last edited by PJmax; 03-13-19 at 05:16 PM. Reason: reoriented picture/added two closeup pics
Old 03-13-19, 04:35 AM
P
Received 2,269 Upvotes on 2,021 Posts
Keep in mind that most on this forum are in North America so our products could be very different. The ones I've run into are either glued in place with sealant or was a very firm press fit into a barbed like gasket that seems to make it easy to insert the glass but difficult to remove.
Old 03-13-19, 06:26 AM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
Yep... you will likely need suction cups and deglazing tools to cut the sealant if that's what was used. Looks like you have a black gasket.... if it is a spline gasket (one on each side of the glass) it will pull out first.
But if it is a marine glazing boot, it surrounds the glass like a glove, and you have to pull the glass (and boot) out of the aluminum, or possibly cut the sealant holding the aluminum to the wall. Hard to say exactly how it was installed.
Old 03-18-19, 01:16 PM
H
Thank you very much everyone. I finally managed to get it removed!
