Toilet water level/fill tube setting
Received 0 Votes
Hi, I have done some searching and believe my problem may be the fill tube or level setting, but I am not sure what to do next.
This toilet is not used often. I suspected water leak so I changed the flapper, filled the tank, shut the water off, then added blue dye. It has been about 3 weeks and as you can see in the pictures, there is tank water loss. It is not hot so I don't think it is evaporation. The water in the bowl is not blue and there is not water on the floor.
That leads me to believe it is a fill tube or tank water level setting issue. The tanks says set water level 1" below overflow top. And that is where the water level is.
So what do I do next? Adjust the black plastic screw?
https://live.staticflickr.com/65535/...817d4bb1_b.jpg
https://live.staticflickr.com/65535/...12b457d2_b.jpg
