Sink Hose Replacement Help
Hello - I have now gone to the store three times and returned with an incompatible hose every time. Can someone please help me identify this hose piece? The sink is a pull out faucet. I cannot seem to find it online. Thanks!
Welcome to the forums.
Your picture is linked to google mail. Not quite sure where that would be but it would be a private picture. It can't be seen here.
Try posting the picture directly to the board............ How-to-insert-pictures.
You won't find a replacement hose for the pull out faucet sprayer combo spout. You must go back to the manufacturer. If it's a name brand like MOEN or Delta they will replace for free.
https://www.google.com/search?q=pull...PlBX-HjR_5WuM:
At most home centers you will only find the flex hoses underneath the sink used to connect the faucet to the house's plumbing. You might also find the hose and/or sprayer for old style faucets that have the sprayer separate from the faucet. As Norm201 mentioned. You will not find the hose for a sprayer faucet as the hose is part of the faucet itself.
Thanks everyone - ended up needing to replace the faucet, none of the hose attachments i found worked and there was no branding to find a manufacturer. Appreciate the help.
