how to clean toilet rim jets?
Old 05-18-19, 06:49 PM
F
I had a weak flush toilet. Used 6 feet snake and seems no clog on the pipe. Bucket water test works fine too.
The rim jets are dirty. I used toilet bowl cleaner to clean the rim jets area. Also duct taped all jets and then pour hot white vinegar into overflow tune to let it sit 2 hours. Repeated vinegar again. Seems improved a little bit but not much. I read online that people also try to use some kind of acid instead of white vinegar, I am not sure it is safe or not.
Any suggestion what next step I should do?
Thanks.
Old 05-18-19, 07:12 PM
XSleeper's Avatar
Received 1,528 Votes on 1,372 Posts
You would want to be very careful with any type of acid since if it is mixed too strong it can etch the porcelain. I would probably use limeaway or crl or similar and keep at it with a bristle brush or pipe cleaner and repeat until it's clean.
Toilets are cheap enough that if I had to work on it for much more than an hour, it would no longer be worth my time... so if that's the case with yours and its too far gone you could just get a new one and save the time and effort and cost of cleaning supplies.
fei2010 voted this post useful.
Old 05-19-19, 02:35 AM
Received 674 Votes on 597 Posts
Seems like back when I was young I took a wire [coat hanger?] to run in/out of the holes to clean them out.
Old 05-19-19, 06:29 AM
airmark's Avatar
Received 4 Votes on 3 Posts
I used air pressure (co2 cartridge) at the flapper valve with a wet towel for containment. It blew a cup of brown sludge out the rim. Sludge blew downward and hit the bowl water level and created a mess, splashing upward in my face. But after one purge, the plugged up toliet worked like new.
Old 05-19-19, 06:32 AM
Received 125 Votes on 110 Posts
Pipe cleaners work for me.
https://www.the-crafts-outlet.com/pr...xoCuPcQAvD_BwE
Old 05-19-19, 02:42 PM
F
Thanks for all the suggestions! I definitely spent more than 1 hour already...
I was also thinking of replace it as well, does this looks a good one? reviews seems pretty good: https://www.amazon.com/gp/product/B0...KIKX0DER&psc=1
Old 05-19-19, 02:46 PM
F
@airmark, never thought of using air pressure. need to seal the bowl first
Old 05-19-19, 06:39 PM
R
Received 65 Votes on 50 Posts
Yes, that TOTO is a very good toilet. Used them for many years with no issues what so ever. But I would make sure to get the 1.6 gal flush model.
Old 05-20-19, 09:02 AM
CasualJoe's Avatar
Received 164 Votes on 147 Posts
I haven't bought a new toilet in many years and have noticed now there are quite a few 1.28 gallon flush models. I am just curious if the 1.28 gallon models are satisfactory or would it be wise to stay with the 1.6 gallon flush models?
Old 05-20-19, 09:44 AM
R
I have no idea how good the 1.28 gal models are, but I do think 1.6 offers plenty of water saving compared to the old toilets. Sooner or later I'm afraid they will get the water per flush so low they won't flush at all. Kind of like the new HE washing machines and their great success stories.
