5/8 in between old toilet flange and new title
Old 05-24-19, 03:30 PM
B
The old toilet flange and new title floor has a 5/8 in difference. The old toilet flange has some cement in it from the new floor which is about 1 in thick. Should I try and clean out the old flange by using small drill bit or some other means. Or can I just add a new toilet flange on top of the old flange.
PS: I can not delete any old pictures to add a new one. How can I delete them or make them a lot smaller.
Old 05-25-19, 03:16 AM
P
Received 630 Votes on 582 Posts
You are limited to 10 gig of photos. You cannot delete old ones because it causes problems in those threads when your photos disappear.
You need to remove any mortar or thinset that has gotten into the drain. You don't want it causing a clog.
Old 05-25-19, 04:13 AM
B
Nothing is in the drain. The mortar got under where the screws go holding the bowl in place.
Old 05-25-19, 04:50 PM
P
You will need to remove it just the same. You need to be able to slide the toilet mounting bolts in those slots.
Old 05-25-19, 04:57 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
If the flange is below floor 5/8 use two wax seals.. If you can raise flange that may be better, but I would have to see it...
Just use small chisel to knock out cement..
Old 05-25-19, 05:36 PM
Received 1,113 Votes on 1,033 Posts
Bob..... you get 10mb of attachment storage. You are currently at 2.5mb. You have 7.5mb left.
Old 05-26-19, 05:07 AM
T
This product worked well for my slab problem. (If you cant get bolts in the existing)
Wax ring(s) go between this an the existing flange. The rubber gasket seals against the toilet.
https://www.homedepot.com/p/NEXT-by-...672X/204403879
