toilet pipe cut 1 1/4 below ground level
Old 06-24-19, 04:49 PM
R
Exclamation toilet pipe cut 1 1/4 below ground level
So because I had no idea what I was doing. I had cut the pipe before I filled everything back in with cement.
The end result was that I had cut the toilet pipe 1 1/4" below ground level. What is the best way to fix this?
Old 06-24-19, 04:51 PM
Norm201's Avatar
Received 230 Votes on 205 Posts
Old 06-24-19, 06:21 PM
R
I'm assuming the flange extender is a flange with an extended neck? The flange I currently have has a 2" neck. that means it should slide over the pipe 3/4".
How far does one pipe have to overlap the other for a proper seal?
