Help identify rough in drains.
Old 07-02-19, 08:35 AM
B
Can you please help identify the plumbing for this basement rough in. Itís supposed to be for a shower, sink and toilet. I am guessing there should be a drain for the sink in the wall but there isnít 15Ē of clearance from the toilet drain to the 24Ē vanity. Also wondering about the pipe outside the wall it doesnít seem to come out of the roof or anywhere that I can see. Thank you!
Old 07-02-19, 08:41 AM
P
Received 629 Votes on 581 Posts
The shower drain will be 2" diameter. The toilet 3" or 4" while the sink is likely 1 1/2".
Old 07-02-19, 09:32 AM
B
The small drain is 2” so should there be a 1-1/2 in the wall?
Old 07-02-19, 07:25 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
The small drain is 2Ē so should there be a 1-1/2 in the wall?
Yes.. 1 1/2 in wall
That 2" is for a shower. and looks like the walls were put up without sizing a shower pan.. Uggg more work for you..
3" pipe needs to be roughed 10, 12, or 14" from wall to center.
Old 07-02-19, 07:36 PM
B
What is the small pipe for that is on the outside of the wall? I don’t see where it comes out. Thank you so much!
Old 07-02-19, 07:42 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
I would guess that they intended for a wall to be built perpendicular to the wall pictured in photo 4. And that the small pipe outside the wall is maybe supposed to be extended down and over for a vent for your sink.
Old 07-03-19, 04:26 AM
P
As a side note did anyone notice all the holes drilled for electrcial in the bottom edge of the floor joists? They don't look like they are 2" in from the edge.
