removing shower handle face plate
Old 07-06-19, 08:22 AM
Received 1 Vote on 1 Post
I want to remove a shower handle face plate (two Phillips head screws), however, the handle is in the way. I thought I could use a ratchet to get under the handle but the space is too narrow. What is the easiest way to loosen the two screws? Thanks
Old 07-06-19, 09:17 AM
Norm201's Avatar
Received 227 Votes on 202 Posts
Look for a set screw on the underside of the handle.
Shepweiler voted this post useful.
Old 07-06-19, 09:34 AM
P
Received 608 Votes on 561 Posts
You will need an Allen wrench to remove the handle. Once the handle is off you can remove the two screws holding the escutcheon plate in place. If you want to remove the decorative stem cover it just slides into place.
Old 07-06-19, 10:16 AM
I removed the allen screw on the underside of the handle, but still unable to remove the handle.
Old 07-06-19, 10:46 AM
Nevermind it came off ! Thanks
