circa 1987 Delta shower valve cartridge replacement
Old 07-10-19, 07:34 PM
Attached photo shows circa 1987 Delta shower valve that's leaking by at 20dpm.
Is the following the correct replacement cartridge?
Cartridge Assembly -1300/1400 Series (04/2006 and earlier) -Model RP19804
Nearest retail is >1HR away, therefore want to verify shopping the Right Stuff.
Any related tips/recommendations appreciated!
THANKS
Old 07-10-19, 07:47 PM
Received 1,113 Votes on 1,033 Posts
Without an exact model of your faucet.....I'd recommend pulling the cartridge out and taking it with you.
Old 07-10-19, 07:59 PM
XSleeper's Avatar
Received 675 Votes on 624 Posts
Can't tell from the picture where your machine screw holes are. The 1300 and 1400 had a pair of machine screws diagonal from each other... top right, bottom left. The 1600 had a pair below the handle... lower left, lower right. They take different cartridges. The 1600 cartridge is RP1991. The various 600 series (6xx) also has 2 screws below, but it doesn't even have a cartridge... it has ball, seats, springs, cam packing.
See pages 66-73. https://www.deltafaucet.com/for-prof...ogs--brochures
I agree you should disassemble it and see which schematic fits your faucet.
Old 07-10-19, 08:10 PM
Thanks for your response PJMax-
If no posters can confirm the RP19804 replacement cartridge is correct, or at least a "best bet", then I'll buy the RP19804 cartridge to have on hand when removing the current cartridge and hope it's the right one.
Water to entire house will be S/D, therefore goal is to avoid inconvenience of extended outage due to complications (cartridge damaged by removal, and/or wrong cartridge on hand, or correct cartridge not readily available).
From a short Google search, appeared that Model RP19804 is the replacement for 1987 cartridges -just looking for responses from anyone with knowledge in this regard.
Old 07-10-19, 08:21 PM
Thanks XSleeper -that's good info-
Think there's a pair of screws below the handle... lower left, lower right.
This is at a relative's house, will have them verify.
At the link U provided, which brochure do I select to view pp 66-72?
THX
Old 07-10-19, 08:24 PM
XSleeper's Avatar
Sorry thought i was pasting the right one... it's in the Delta 2000 parts catalog. I worry that its not a cartridge.
Old 07-10-19, 08:40 PM
Thanks -got it.
Similar handle is shown on pp for the 600 series and for the 1300/1400 series.
Assuming that's a clue, appears verification of the screw location will narrow this down to one or the other(?)
THANKS
Old 07-10-19, 08:50 PM
XSleeper's Avatar
Well since this is a 1987 faucet, I would just guess it's 600 series with the old ball / seat / springs. You will know once you disasemble. I think all the others are far too modern. Yeah, the screw location is a big clue.
I bet if you take the handle off, you will see the RP250 adjusting ring (page 66).
Old 07-11-19, 05:05 AM
A
Received 67 Votes on 61 Posts
Do you pull it straight out to turn it on, and it rotates only clockwise or counterclockwise to control the temperature, then straight in to turn it off? Or is more of a joystick, as in mounted on a ball? I'm thinking it's the former, and if so I think you're on the right track with the cartridge. I only remember seeing a few with that style handle on a ball type, recall thinking that they either came out during the transition time or someone had installed a different handle because they like that style better.
Old 07-11-19, 05:13 AM
XSleeper's Avatar
Like the dial shows, up turns it on... left and right twist controls temperature. I think it's a 600 series, no cartridge, just ball, seat, springs behind parts that are probably all corroded with lime and hard to remove.
Old 07-11-19, 09:42 AM
A
I'll have to take your word on what it says because between the image getting more grainy as I enlarge it and having to wear my old trifocals because I broke my newest ones I can't quite make it out. But in that case I will add what I was going to mention before. If it is a ball, and if you compare the old one to the new one you might see a slight difference in the length of the slots in the ball that sit over the pins in the faucet. But if it's like the one I was working on that's okay. I remember noticing it right away and toying with it a bit, and can't remember now if I actually heard or read this or got there on my own, but came to the conclusion that the reason for the difference was to reduce movement toward "hot" on the older "pre-tempering" valves. Otherwise though it worked fine and still had plenty of hot water.
Old 07-11-19, 11:37 AM
Screws are left/right below the handle -therefore it's either a 1600 series (RP1991 cartridge) or 600 series (ball/seats/springs/cam packing).
At next opportunity, will remove the handle to look for the RP250 adjusting ring (page 66) indicating it's a 600 series.
If a 600 series, this will be first time replacing a ball/seat/spring vs a cartridge.
Is this a generic procedure that's normally not a big challenge?
Is a standard rebuild kit sold that will stop the 20dpm leakby?
THANKS
Old 07-11-19, 11:50 AM
A
A couple more pieces, but no, I would not call it challenging at all. The only "tricky" part, and it's not really, is getting the old cups and springs out and the new ones in. I just grab a scribe from my machinists box, one with a straight end and a crooked end to lift the springs out, but a piece of wire or a pair of tweezers will work fine. As I mentioned, the ball has a slot or two, and the fixture has a corresponding dimple, pin, whatever you want to call it, so lines right up.
Old 07-11-19, 12:14 PM
Appears case closed with this verified as a 600 Series since the handle is lifted to turn on the water(?)
haha- Replies appear to contradict?
"assuming you can get it apart" vs "not challenging at all"
Have a hook&pick set that should work well to remove the springs.
The linked renovation kit is pricey, and has only 19 reviews-
Leads me to wonder if replacing vs renovate could be the more common and better decision for this @32year old valve?
THANKS
Old 07-11-19, 12:18 PM
XSleeper's Avatar
It's that outside ring that is sometimes hard to turn loose. Have some crl or limeaway and a toothbrush handy.
Well, replacing means tearing the wall open and replumbing it... so no, that's not the cheaper option. LOL
As far as plumbing goes, I wouldn't say that $40 is pricy. It will look like brand new once your done.
Old 07-11-19, 12:32 PM
Thanks XSleeper-
Will order the renovation kit, and be ready for a battle to remove the old valve.
Your time and provided info (and others responding) much appreciated!
Surfin'
Old 07-16-19, 08:36 AM
CasualJoe's Avatar
Received 86 Votes on 76 Posts
I would order the renovation kit. It's not the 1600 because it looks like you lift the handle to turn it on.
I think I need something like this kit for a 1978 or 79 Delta tub faucet, but I was wondering if this is an aftermarket manufacturer. I saw nowhere that Delta was the manufacturer and I generally try to stay with OEM parts. I also saw when reading the reviews that the escutcheon is plastic, that concerns me. Does Delta make a renovation kit similar to this one?
Old 07-24-19, 07:07 AM
CasualJoe's Avatar
I am still interested in the renovation kit and have done a little more looking which is making me more confused. Amazon also has a renovation kit with the same basic description only it has a lever handle rather than a ball, also costs $30 more. My older faucet has the ball handle that is lifted to turn on and turned either left or right for hot and cold water. Does this similar kit with the lever work that way too?
https://www.amazon.com/Delta-RP54870.../dp/B003NLHR40
I found this same kit on Delta's website for $131. The Amazon $40 renovation kit is looking better all the time.
Old 07-24-19, 08:14 AM
Made same observations as you, CasualJoe-
The @$70 kit you linked is clearly OEM/Delta.
For further confusion, reference the 4th of 4 images for this product that shows the KNOB (not lever) handle. Same image is used for the $40 kit.
A search for "handle" in Customer Q's and Answers provided info that appears to indicate the lever replaces the knob.
The $40 "Renovation Kit for Delta RP54870" kit is not clearly OEM,
Q asking for verification OEM wasn't answered. Therefore think $40 kit is risky.
Direct from Delta at $131 is out of the question.
Think I'll be playing it safe with the $70 kit, after first get an opportunity to pull the knob/plate off for a look to verify no surprises.
  #21
Old 07-25-19, 11:00 AM
CasualJoe's Avatar
I hope you post again after you get the $70 kit installed, I am really interested in what you think of it. I have no problem using a lever rather than a ball and am thinking that the lever and ball are probably interchangeable.
  #22
Old 07-29-19, 11:30 AM
A couple follow-up pics -do these help make it reasonably certain that the following is correct kit to rebuild this circa 1987 valve?
Delta RP54870 Renovation Kit - 600 Series Tub and Shower
THANKS
  #23
Old 07-30-19, 05:17 PM
CasualJoe's Avatar
Not an expert by any means, but I think the Delta RP54870 Renovation Kit will work for you.
I previously said that I thought the lever and ball handles were interchangeable, but after thinking about it, I know that cannot be. It's easy to see in your pictures the diamond shaped stem on the faucet ball and that the stem has a threaded hole in the end, that style will only accept a ball handle. The lever handles have a setscrew under the lever that tightens onto a flat side of the faucet ball stem. They are definitely not interchangeable.
  #24
Old 07-30-19, 06:20 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
In my 30 years of plumbing experience I would not waste a dime on repair kits and the like..
I would cut the wall open in the back and replace with a modern diverter..
Moen.
we do them here for around $800-$900.. Your prices may vary.
Those single lever deltas came out in 1974, innovative at first, junk today.
Just my opinion.
  #25
Old 07-30-19, 07:09 PM
Thanks for your replies-
Lawrosa, your perspective is interesting b/c asked following in Post #15:
Only response noted the high cost to replace the valve.
Your vote now makes the score 1:1 for repair vs replace-
I can open/close the wall, but not DIY changing the valve, therefore expect total cost < $500.
This valve lasted 32yr: if a rebuild = 30 more years, then that works for me.
Any other opinions regarding best option (repair vs. replace)?
Thanks
