Slow toilet leak?
Old 07-13-19, 07:03 AM
Slow toilet leak?
Hey guys,
I reinstalled my toilet after doing the floor in the bathroom and I think its got a slow leak at the floor. Ive been noticing the grout around the base seems to be wet.
When I first tried with the standard wax ring it wasn't high enough so I bought one of those reusable gaskets. Shimmed the front since it would wobble a bit and bolted it down. Seemed ok for a bit but again noticed the grout.
Couple days ago I bought one of those jumbo rings and tried that. No luck there.
Anyone got a product they would recommend I try to get it to seal better?
Old 07-13-19, 07:11 AM
XSleeper's Avatar
Received 673 Votes on 622 Posts
Is the flange below the floor? If so you probably need a flange extender. If not, you are probably just ruining the wax seal when you set it down. You have one shot to set it down perfectly.
Old 07-13-19, 07:16 AM
Yeah I think it's Jusssssst. below the floor... I'm going to pull it again and look at it.
Old 07-13-19, 12:59 PM
P
Received 624 Votes on 577 Posts
Wax rings are sold in different sizes. If you used a standard try a jumbo next time.
Old 07-13-19, 01:10 PM
XSleeper's Avatar
Also, occasionally you get a toilet that benefits from having a rubber flange, like the Harvey's No Seep #1, #10 or #50. Then there are reinforced wax rings. And wax rings that are JUST wax. Part of it is getting the right ring for your particular toilet/flange. The other part is not damaging it when you set the toilet over the bolts.
Old 07-13-19, 04:39 PM
W
Received 12 Votes on 10 Posts
Hi, Water travels down hill. Make sure the water you see around the base of the toilet isn't leaking from the tank or supply line.
Good luck Woodbutcher
Old 07-14-19, 05:11 AM
Yeah tried a jumbo...
When I pulled it the flange was almost flush with the floor. I put a extension on it and used one of the reusable rings and it seems to be ok now... It bolted down better anyways... So we'll see
Old 07-14-19, 07:01 AM
XSleeper's Avatar
Hope you sealed the extension to the original flange with silicone.
Old 07-14-19, 07:33 AM
Yes sir... not quiet 25 char so add more
