Drain/Plumbing for basement sink
We are installing a new vanity in our basement half bath. The drain for the existing sink comes from side wall which is 90 degrees from the wall where the water lines are located. The good news is I have total access behind both walls. The new vanity will not allow the existing drain hookup. Is it within code and possible to hook up the new drain thru the same wall as the water lines (normal position) and run the plumbing around the wall to the sewer line and attach to it. Total run around the wall would be about 3-4 feet.
