Leaking under toilet
Old 08-27-19, 01:53 PM
I've noticed leaking (after flushing) coming from under the toilet. At first I thought it was a bad gasket seal. Just bought a new wax gasket (both had horns). Still leaking. Cracked tank? If there is a crack then I can't see it. I've inspected this thing. I also tested running water through it outside while having it seated on a ledge. Water seems to be coming out the spout normally.
Do I need to add a flange on the floor to improve the seal?
Old 08-27-19, 04:37 PM
Solution: I placed the wax gasket on top of the floor pipe. Then I fashioned about a 1/4" to 3/8" wax ring around the underside of the toilet, sticking bits of wax on there like putty. So that wax presses up against the gasket when I seat the toilet. That little extra height of wax seems to have fixed it. No leaking so far!
Old 08-27-19, 04:52 PM
Received 474 Votes on 444 Posts
Sometimes I've stacked two gaskets together to make the seal.
AndyRooney voted this post useful.
Old 08-27-19, 05:18 PM
I must say that applying the wax to the under side of the bowl like putty sticks to the toilet REALLY well! If there ever is a leak then it's gonna be where the wax meets the wax when setting the toilet down on top of the wax gasket, and even that would seem unlikely
Old 08-27-19, 05:44 PM
Norm201's Avatar
Received 106 Votes on 97 Posts
Glad you have it fixed. But the look of that flange is nasty. You should've replaced the flange/ or put one on the floor as you suggested. The rust is so bad I won't be surprised if you see leaking again in the near future.
Old 08-27-19, 06:46 PM
What type of flange do I need? One like this? https://www.homedepot.com/p/Oatey-Oa...6552/205855426
Old 08-27-19, 07:07 PM
The pictures are good but I can't tell what it is.
Is that a lead bend ?
It doesn't look like PVC.
Messing with flanges can some times be a lesson in futility.
Old 08-27-19, 08:12 PM
Oh this house was built in like 1956. It's cast iron or something like that. No PVC.
