Replace bathroom faucet cartridge
Old 11-10-19, 09:38 AM
A
I'm attempting to replace the cold-side cartridge in my bathroom faucet. I'm having two problems. First, I don't know how I can loosen the nut, which is in a depressed area that I can't access with the tools I have. Is this cartridge even removable? Second, I can't seem locate the manufacturer. I do see the number 4208 on the translucent plastic collar in the picture. I'd appreciate any guidance. Thank you.
Old 11-10-19, 09:50 AM
Norm201's Avatar
Received 715 Upvotes on 636 Posts
I'm thinking this might be a Larson brand unit. I also think you need a socket wrench to remove it.
Old 11-10-19, 02:52 PM
A
I do have a socket wrench, but the stem is in the way. Do you have a specific wrench suggestion? Thank you.
Old 11-10-19, 02:54 PM
Norm201's Avatar
You need a deep socket.__________________________
Old 11-10-19, 03:15 PM
A
Received 73 Upvotes on 66 Posts
Agreed, looks like a deep well socket will do the trick. And it's possible that it's a left hand thread so take it easy.
Old 11-15-19, 11:02 AM
CasualJoe's Avatar
Received 183 Upvotes on 165 Posts
Looks to me like you don't have cartridges, but stems that may need replacing.
Old 11-19-19, 04:41 PM
A
How can you tell it's a left-hand thread? Thank you.
Old 11-19-19, 06:54 PM
CasualJoe's Avatar
You will need a socket to remove the stems, they are right hand threaded into the faucet body. Take a stem to a good hardware store and they can maybe match it up or find a replacement in a catalog and order you new ones.
Old 11-20-19, 05:34 AM
Norm201's Avatar
I'd like to suggest, you buy a new faucet set. For the work involved and the price you'll get a new unit that does use a cartridge style stem that will give many years of service and if you buy a name brand it will be lifetime warranty.
Old 11-20-19, 09:22 AM
CasualJoe's Avatar
A new modern faucet is absolutely the best fix. Stay away from store branded faucets such as Tuscany by Menard's, Glacier Bay by Home Depot and Project Source from Lowes. I recommend Delta with Moen as my second choice.
