Toilet flange won't fit
Old 11-30-19, 06:25 PM
K
Having some trouble replacing a toilet flange, toilet was rocking/leaking, pulled it off and of course the flange was broken. Managed to chisel off the old flange, went and got a new one but it would appear they are the exact same size...or perhaps the drain is slightly smaller. I don't know if I have the wrong size/style flange or what. I've read that PVC pipe clearances can be tight, but I can't even get this one started at all.
Any advice is appreciated.
Last edited by PJmax; 11-30-19 at 10:42 PM. Reason: resized/imported pictures from link
Old 12-01-19, 04:44 AM
pugsl's Avatar
Received 74 Votes on 67 Posts
Most likely you have wrong flange. They make a flange that will go into the black pipe. I had to get one from plumbing supply store. Think I saw one at Lowes the other day,
Old 12-01-19, 05:07 AM
P
Received 682 Votes on 629 Posts
Look for a toilet repair flange. It has a protruding end with gasket that you shove down into your existing pipe.
Old 12-01-19, 10:46 AM
CasualJoe's Avatar
Received 92 Votes on 82 Posts
You bought a PVC flange and what you have is not PVC.
Old 12-01-19, 12:47 PM
K
I seem to be having a hard time finding one that fits a 4 inch pipe. That is the type of flange that fits down into the pipe.
Old 12-01-19, 12:55 PM
Received 1,184 Votes on 1,096 Posts
Different brands - same type of product.....
Home Depot
Lowes
Killawattz voted this post useful.
Old 12-01-19, 03:23 PM
K
Thank you so much. I for whatever reason couldn't find that, all I saw was cast iron 4 inch, not ABS suited stuff.
Old 12-01-19, 07:20 PM
lawrosa's Avatar
Super Moderator
Received 60 Votes on 52 Posts
This is better...Use this one.
https://www.homedepot.com/p/Oatey-4-...3539/100139480
