Advice about my rusted closet flange
Hey all,
I noticed a leak in my drywall and found it to be my toilet from the second floor. I removed the toilet and found this mess. Mind you, I've already cleaned up the area. (FYI, I've plugged up the hole so no gasses leak out)
The outer metal flange is rusted and a screw had easily broke in half when I was removing the spacer that was placed on top of the metal. (Removed in the pictures)
Also, there was a good deal of "dirt", which I'm assuming was just the rotted wood floor?
Based on what you see in these pictures, is it worth salvaging the wood sub-floor and adding a flange repair kit? I'll also use a spacer to bring it above the tile - which it was not with the previous installer.
Or, do I need to completely remove the old flange to repair the sub-floor?
Looks like its a glue in hub type flange.. I see the elbow right below floor..
An inside pipe glue flange would be best... Most likly pvc to abs..
Add a spacer to keep the flange at or above floor level. Cut to size.
But looks like they have a glue inside pipe abs model.. Just glue it over the old but be sure to line up bolt holes properly.
https://www.lowes.com/pd/Oatey-ABS-Flange/50315063
xMarc
voted this post useful.
xMarc
Mike, will an inside pipe glue flange fit into the old flange? What about the rusted metal ring, does it stay or need to be removed.
I hate those old flanges with the steel rings that rust away and I think I have one coming up to be replaced in my future too. The ones I see today are stainless, but I think I'd prefer to just use a PVC flange if it were a new installation.
Mike, one more question. The OP has a spacer because the flange was installed on the subfloor, but my flange to be replaced is installed on top of porcelain tile with no spacer. Will an inside pipe glue flange still be the one to use or is there a different product that might work better?
But some times if sub floor of slab I use half moons..
I am glad you included that picture showing an application of the half moons, that might be what I'll need. This porcelain tile floor is over a concrete base and is 95 years old, I know there is a wood subfloor under it somewhere, just don't know how far down for sure.
Where can I find those half moons?
Hey all,
I removed the rusted metal ring and got down to the subfloor. I had 2" of underlayment to get through! Fortunately, the subfloor was not soft.
My current plan is to replace the metal ring that rusted with a stainless steel flange. The plastic inside the pipe is fine. It's available from Lowe's and made by Oatey. I'm sure there are others around as well!
Oatey Stainless Steel Flange
I'll upload some updated pics, a bit later today, of the ring removed and underlayment taken down.
I plan on replacing the underlayment with cement board and using spacers to bring my flange above the tile.
If anyone has input or questions, please feel free to ask/share!
EDIT for pictures::::
The first pic is with the metal ring flange just removed. I used aviation sheers to cut it and a chisel to pull it back.
The second pic is when I took out about 2" of underlayment - cement board. Previous owner had tiled over the vinyl that was originally installed when the house was built.
Last edited by PJmax; 01-15-20 at 06:52 PM. Reason: imported/cropped/resized pictures
Norm201
Casualjoe, the link in my previous post should send you to a metal flange that fits around, two half moons, PVC/abs pipe.
Anyone have ideas on how to raise my flange up a full inch so that it's above my tile? It's hard to see in the pictures previously, but the flange is much lower than the tile and that's what caused my leak.
I see some spacers only allow a max of two to be put together. That would only give me .5" 's of lift.
Thoughts/ideas are welcomed!
