How to get handles off
Hello
The handle on the cold water side is stuck and I need to get it off to either fix or replace it. Based in what I see below it slides out from the bottom so requires I get the handles off. There are no screws and no cap that I can tell with a hidden Allen screw. I tried also twisting the base counter clockwise with no luck. I can't tell the brand either unfortunately. Anyone have any idea what to do to get this off?
Thanks.
Thanks.
Lesson learned: Save paperwork for ALL faucets.
It could be a Grohe faucet.
If there is absolutely no set screw visible..... the handle may just pull straight off.
CLR is the same as Lime-A-way. Again if there are no other visible means such as set screws, snap rings, etc...The problem I see is how are you going to get the CLR up in there and soaking. Perhaps with one of those lab bottles with the inverted straw.
You're absolutely sure there are no signs of the manufacturer?
Years back I had a MOEN cartridge that was so calcified to the body, I had to buy a special puller just for that purpose.
