snapped bathtub drain pipe
Old 10-02-20, 11:54 AM
I am remodeling my bathroom and accidentally snapped the drainpipe while removing the bath tub.there isn't much left on the end connecting to the t joint. Is there a way I can repair the pipe or do I need to replace the whole joint?
Old 10-02-20, 03:07 PM
P
Received 631 Votes on 583 Posts
Which fitting are you asking about? Is it the one on the left with what looks like tub still attached?
Old 10-02-20, 03:15 PM
Received 1,113 Votes on 1,033 Posts
Very busy junction there.
Trying to figure out if it's an actual stack as the fittings connected are not all correct.
Old 10-02-20, 10:26 PM
I'll be honest I was moving a little fast and forgot to remove the drain from the bottom of the tub before I lifted up, ended up just cutting it out for ease, but the damage was done. The subfloor is completely removed and what you're looking at is the combination of the bathtub and toilet drain.
