Garbage disposal red reset button recessed inside?
Hello
I was stupid enough to throw a whole orange into my garbage disposal, and it shut it down. The orange is out and there is no blockage, but the disposal won't turn back on.
The reset button seems to be broken or recessed inside
I used the hex tool to rotate it, also unplugged it and turned off the breaker panel but no luck
any ideas? is that the red reset button that slid to the left and is visible under the rectangular hole?
Insinkerator says every one of their models has a thermal safety breaker. The red part should pop out if it's tripped. Yours looks different than the other models. Can't tell if maybe the switch moved in it's bracket.
In the following link..... there is a number you can text for factory help. That definitely looks like a manufacturing issue. They may be able to help you quickly.,
Hi PJMAx,
It turns out, the red switch got pushed in and got out of alignment . Either the homeowners before us pushed it in too aggressively (or maybe one of us did it - however none of us is admitting it
Anyway, I got it to work after I messed around with the red button using a chopstick, and it took some wiggling before it worked.
I decided to replace it before it acted up again when the sink is blocked. I got lucky today as there was no blockage in the sink, so the work was pretty clean. Picked up the exact same model at home depot for $99 this afternoon. Yes it does have a red button.
Since it was the exact same model, it saved me a lot of time in terms of installing the parts on top of the sink. Didn't even have to use plumbers putty. I am not very good at this stuff, but It was pretty quick and easy - but boy, crawling under the sink and trying to balance the new unit and twist it closed was the biggest and most time consuming part !!
Hope I did it correctly. I guess we will find out !!!
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/558x653/fct_71faa0e86e8d5d1d0d1ec8709535023144fbc448.jpeg[/img]
[i]I have tried a strap wrench on the cover to no avail, probably out close to 60 lb of torque on it, broke the strap wrench. the brand on the cover plate was price pfister but not positive that plate and this match. Soak it in something? Any ideas appreciated? [/i]
We have a large tub with a low pony wall for the faucets at one end and no adjacent walls to attach a grab bar. Stepping in/out is getting a little risky at age 80. A floor to ceiling pole would work, but seem rather obtuse. And besides, I don't want to encourage my wife into thinking she should take up pole dancing anymore!:) I can envision sort of a "U" shaped bar from the top of the pony wall to the sill at the edge of the tub, but where can such an item be obtained/made? Hoping for some suggestions and ideas.
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/292x600/20201222_110335_4fad7b878e3f6a50587a86ccb40c51e57bc66aa9.jpg[/img]
