Leak in Supply Line Under Sink
Old 12-28-20, 10:05 PM
N
Hi all:
So I have a slight leak in the supply line under the bathroom sink (pic attached).
It was working fine but there was a leak in the top portion of the supply line (which attaches to the faucet) and in the process of tightening the top portion, this new leak has appeared.
As you may be able to see from the location of the water droplets on the nut, the leak is in between the nut and where the braided part of the supply line begins. So the leak is in the supply line itself.
Is there a fix to this or do I need to replace the supply line? It is at least 12 years old.
Getting to the top part of the supply line was very challenging because it is a tight space and I do not have a basin wrench, and I used an adjustable wrench but it worked. I am not looking forward to working that space again!
Thanks!
Old 12-28-20, 10:17 PM
XSleeper's Avatar
Received 1,580 Likes on 1,416 Posts
Replace the supply line. The rubber has probably gotten old. Do not overtighten the new one as you put it on. It just gets snugged up, not cranked as hard as possible... That can cause the new one to leak.
The following 3 users liked this post by XSleeper:
Old 12-29-20, 06:29 AM
P
Received 1,629 Likes on 1,462 Posts
Yes, replace the supply line. They are inexpensive and easy to replace. A new one will only need a mild "snugging up" to be water tight. As SXleeper mentioned do not over tighten as that can make things worse.
The following users liked this post:
Old 01-04-21, 03:19 PM
N
Thanks for the helpful replies.
I am not so worried about connecting the lower part of the supply line because it is easy to get to.
I am more concerned about the top part which is SO DARN hard to get to!
Is there a supply line I can buy that has an easier way to connect at the top, such as a plastic rotator that I can tighten by hand? Does the pipe pictured allow it to be hand tightened?
Old 01-04-21, 03:50 PM
XSleeper's Avatar
The large end is hand tightened, the bottom one will need a wrench, but it just needs to be snug.
Old 01-05-21, 06:26 AM
Norm201's Avatar
DO NOT buy the plastic supply lines . But the SS braided ones. If you don't trust the no name brand sitting in the bin at the home improvement store, buy the name brand ones with tag on it. That plastic will get old and brittle after years and will crack at the slightest touch. And as stated hand tighten the connection then maybe a 1/4 turn to snug it down.
Old 01-09-21, 01:23 PM
P
I would buy a stainless steel braided line that has metal connectors instead of the cheap plastic connector shown on the image. Plastic connectors can crack and then break, causing a flood.
Old 01-09-21, 01:51 PM
P
Consider this wrench from Harbor Freight.
12 in. Basin Wrench
