Delta Series 500 Faucet Repair
I'm a pretty good DIY but this is got me crazy. I've replaced the washers, springs and ball in the past with no problem. This time I can't get it to stop leaking from the faucet or it's hard to move. If I tighten the nut its hard to move the handle if I loosen it it leaks out of the threads. What part does the nylon nut with the notches play in the installation. Thanks in advance.
The faucet is from 1990's and no longer made. This is the kit I used and used the short springs which matched the ones I replaced. Thanks again.
Danco 86971 Repair Kit for Delta with Number 212 SS Ball
The faucet style may not be made any more but the internals should be standard fair for the non-diamond 500 series of faucets. It should be a lifetime warranty. DANCO replacement parts or OK, but I would prefer OEM.
Check some of the videos out there.
I did see a number of videos and I tried under lifetime warranty but the answer was only for defects in materials or workmanship and these are normal wear and tear parts. I agree with OEM parts but I've used Danco in the past with no problems. Maybe it's time for a new faucet!!!
WOW!
It was my understanding that DELTA's lifetime warranty covered everything. As far I know that is MOEN's policy.
Can somebody verify what MOEN's warranty policy is?
I've had instances where the operator would deny warranty, but I would call later and get a different operator and warranty was no problem.
PS...I did a little GOOGLing and it appears that the MOEN faucet warranty is a step above DELTA. All parts and finish are covered. No mention of a 5 year limit if you are the original home owner (5 years if through a contractor and commercial use).
Maybe that's why MOEN is the leader.
I've had a problem using the Danco parts. I haven't found them to last very long.
I've also noticed a slight difference in parts.
If you're using that kit with the 212 ball..... your faucet has the round plastic type knob on it.
Delta 500 parts
Delta 500 parts
I paid a pretty good price almost 30 years ago for a Moen tub/shower faucet because I wanted a good one that would last. As I was installing it I found that the arm for the shower head was plastic. The tub spout was also plastic. My local True Value luckily had metal replacements that I bought and installed with a brand new faucet. I wasn't real happy. In that same bath renovation the Moen single handle vanity faucet w/popup drain seemed fine, but wasn't too long till the drain appeared to be rusting. This is in a china vanity bowl, nothing else there to rust.
As I stated in another thread, the days of long lasting items are gone. Today is a disposable society. How do you think a company like MOEN can stay in business if their products never fail? Same with hot water tanks.
