New stool (toilet) not sitting flat on floor
I replaced the stool in my daughter's bathroom due to a cracked tank on the old one. The old one fit perfectly fine on the floor but the new one rocks forward and back despite all my efforts to the contrary. It is stable side to side. I would estimate the gap at the front and back to be about 1/2" when the stool is pushed to the floor at the opposite end. I have started the process to pull the stool and reinstall it but am hoping someone might have some insight as to the problem before I use the only remaining wax seal in the house.
Should it matter, the new toilet is a Niagara Stealth and it is replacing an American Standard Champion 4.
This post is about a toilet.
What type of wax ring and how many are installed?
It sounds like the toilet is being held off the floor by the toilet flange or wax ring. Either there are too many wax rings or the wrong type installed. Or it's a difference in the design of the bowl portion of the toilet.
Did the old commode have any shims under it? It's not uncommon to have to shim a commode to get it to set properly - especially over tile.
It's rarely that a toilet sits 100% flush on a tile floor.
I always carry a package of plastic basin shims with me.
plastic shims
plastic shims
The old wax ring was removed and the current one is the one provided with the toilet. FWIW, I'm the one who installed the old one and it sat flat without any shims. Floor is sheet vinyl, if that matters.
Have you determined if the toilet is hitting the drain flange? If yes, then you will need to lower the flange or get another toilet that has a recessed drain. Some are recessed above the plane of the toilet's bottom while others are flush with the bottom of the toilet.
If the toilet is not hitting the flange I suspect you have a bad, warped bowl. I have seen misshapen ones that made it past QC. If that is the case you'll need to at least replace the bowl or shim it to make it work.
