How can I tell cost of water used when taking a bath?
Hey guys, our Autistic son has been advised by his therapist to take baths to help his anxiety/depression situation but water is very expensive here in NY so I am looking into finding out how much a bathtub filled with water will cost.
That will tell us how often he will be able to use the bathtub.
Our tub was brought years ago at Home Depot so we have no idea about size or model number. I have a friend who works at the local water dept. He said it costs $11 per cubic feet of water.
The specs on the tub show the basin is 53" x 25.5" x 17.5" depth. That's 13.6 cubic feet of water.
Your cost of water is actually $11 per hundred cubic feet (ccf). It's often shortened to 'cubic feet'. So you're actually paying 11 cents per cubic foot. (Google tells me 1 cubic foot = 7.5 gallons by the way)
So to fill the tub, your water cost is about $1.50. You'll also have to pay to heat the water.
(and if anyone is checking my math, it says it's about 100 gallons to fill this tub. But Google tells me the average tub takes only 40-50 gallons... so maybe my math is wrong somewhere. So maybe it's only about half of what I stated above???)
Thanks! That's a lot of math for someone like me unfortunately.
Right, I got from google 1cubic feet is around 8 gallons. First, I have to wonder how my bud at the local water company can make such a BIG mistake, saying 11 per cu.ft when it's actually 11 per "hundred" cu.ft, is there some resource where I can confirm this part?
Next, I am thinking not the entire tub will be filled but filled to max under that triangular knob so if that is the case then how can I calculate how much water is actually in there please?
I'm going to throw something out there.
You need to allow for water level rise when your son gets into the tub by the way. So if you are expecting a certain level before or after your son is in the tub.
Zoft can do the specific math if you need it but you just need to measure your water depth, width & length in inches. (Do this with the water level before your son gets in the tub.)
Length X width = square inches
Then X depth = cubic inches
That will tell you how many cubic inches of water you will need. Then divide that by 12 to get your cubic feet.
So ZORFDT is correct on the cost being per 100 cu.ft:
For the Fiscal Year that began on July 1, 2022, the metered rate for water is $4.30 per 100 cubic feet, and the combined water and sewer charge is $11.13 per 100 cubic feet.
A "billable unit" of water in many cities is abbreviated "ccf" I think for "Roman numeral one hundred", "cubic" and "feet".
Your meter may measure finely enough to measure individual cubic feet where the third digit from the right is the "ccf". Or a mechanical meter may measure even finer where the right most digit wheel for individual cf moves uniformly as opposed to snapping to the next number. Then no need to compute cubic feet by measuring the tub.
The easy way...I'm sure you have a meter. Fill the tub watching the meter. Our bills show useage in Cu. Meters. Figure the cost of heating from A>B if that matters. Probably minimal cost for the great job each bath does.
For around the 3rd time in 8 years my strainer basket in the kitchen sink is able to be turned by hand from the top. It is not leaking this time (yet). Should I be doing something different? I just used plumbers putty and tightened as tight as I could. Should I use Loctite or Teflon tape or something?
The disposal is a big one (I think 3/4hp) and does vibrate a lot. Oddly the disposal side never seems to have the issue. It is the other side of the sink.
Something fell off the bottom of my (relatively) newly installed sink. I think it's a coating to dampen noise (well, that's what Google says it is). My questions are: 1) Why did this fall off? Is it just something that happens or is there something I have done to cause this? 2) I recently installed a new disposer so, see # 1. 3) Should I replace this and what happens if I do not? 4) Any tips on how to replace it?
[img]https://cimg4.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1512x1061/sticky_sise_d4863f9e9c321097ae7b48ba364b975136954c93.jpg[/img]
[img]https://cimg6.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1544x1158/img_0570_c6b6f2b3c18d0b2f8b3136f9b415b720513ccb94.jpg[/img]
[img]https://cimg8.ibsrv.net/gimg/www.doityourselft.com-vbulletin/1512x1128/img_0572_f0bb2fab19e92993fca0cf6de9b173c6a82c526d.jpg[/img]
The pictures don't seem too helpful :-).
As always, thanks for the guidance.
Ken
