Drain clog: orthodontic elastics
Old 12-22-22, 11:18 PM
T
Received 1 Upvote on 1 Post
Hi all,
My bathroom sink is clogged, but when the sink fills the water clears out with slurping noises. I've tried drano repeatedly, and tried one of those little plastic hook things, no dice. I use a retainer and know that some rubber bands from it have gone down the sink, maybe that was it.
Is there a way to clear it myself?
Thanks In advance!
Old 12-22-22, 11:30 PM
Received 1,197 Upvotes on 1,152 Posts
Stop using dangerous chemicals. Run a bunch of water through to dilute/remove those chemicals and then take apart the trap under the sink.
Old 12-22-22, 11:57 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
As noted, get a big plastic tub, clear out the area under the sink, get a wrench or large plyers, note how all the pieces go together and carefully take it all apart and clean out anything inside!
Old 12-23-22, 10:14 PM
T
Thanks!
