Looking for some help with this mixing valve. Right now water is only luke warm. I got to the green dial and tried turning in both directions assuming this is how adjustment would be made. No change in temp. I looked at parts breakdown and wondering what the primary cause of this is. I am assuming the cartridge ? but curious what function the 2 valves play? Also assuming there are 2 service stops to shut off water? lastly any tricks on removing/replacing cartridge. Have done plenty of Delta/Moen and Symmons but this is uncharted territory lol
Xsleeper, thanks for reply ! After looking at parts breakdown this model has 2 check valves which I am assuming if one was stuck could cause the lack of temp control and looking at the cartridge it does not seem to have the sliding mechanism like those in a symmons temptrol. So wondering if anyone has a guess as to which is most likely culprit (check valves or cartridge) ? Only reason being so anal is parts very expensive total checks and cartridge $500. Ouch !!
Hi all,
My bathroom sink is clogged, but when the sink fills the water clears out with slurping noises. I've tried drano repeatedly, and tried one of those little plastic hook things, no dice. I use a retainer and know that some rubber bands from it have gone down the sink, maybe that was it.
Is there a way to clear it myself?
Thanks In advance!
Just got finished installing and noticed that. Is this a new design/method of some sort? If so, is there a name for it? Don't see any mentions in the specs.
