Bathroom Faucet Replacement
Old 01-21-23, 07:24 AM
Bekrah's Avatar
One of these faucets is leaking and I want to repair it.
Also, the chrome plating is coming off on one of the drains.
Do I have to replace the entire sink in order to rectify the chrome plating issue?
Thanks in advance.
The sink on the left is constantly dripping and needs to be replaced.
Chrome plating is coming off in this drain.
Old 01-21-23, 08:02 AM
C
Received 122 Upvotes on 98 Posts
No, you can just replace the drain assembly, they are readily available. If you can, avoid the cheapy plastic type.
You should be able to just repair the faucet, depending on brand/type it may just need washers, or worse case two new stem assemblies and maybe seats. Unless it's a real off-brand, replacement parts are usually available.
Pilot Dane voted this post useful.
Old 01-21-23, 04:10 PM
lawrosa's Avatar
Super Moderator
Received 79 Upvotes on 71 Posts
The chrome plating can be fixed with a simple pop up replacement.. not for the faint of heart if you never done it before..
as far as the leak its probably just a simple cartridge replacement
Old 01-22-23, 08:12 PM
Bekrah's Avatar
Thank you guys.
That was very helpful!
