Fridge has a copper water line that uses a crummy saddle valve under the sink. I'd like to replace with a better solution, though I'm a bit puzzled by the collection of fittings I see already in place. See pics, I'm thinking maybe a previous dishwasher was hooked up to cold and the pex line was capped off? I know this kitchen had a flood at one time (water damage on cabinets), so this may have been part of the fix.
Should I cut the copper pipe at the saddle valve and discard the parts below? Since the pipe below the T isn't being used for anything but the fridge, what kind of fitting would I want for the line to the fridge? I can replace the fridge water line as well if there's a better product.
I would turn off the water and open a faucet to bleed the pressure out of the system. Then I'd unsolder and remove everything coming out the bottom of the "T". Then you can solder on a new section of pipe with a shutoff valve for the fridge water line.
I know soldering is the tried and true best, but I think if you don’t know how to solder you could use a SharkBite valve as in the link. It pushes on like the orange handled SharkBite valve in your picture.
I think that should work. You would have to make a nice square cut. You can get a cheap copper tubing cutter in Home Depot and they work well and it will be easy to make square cut. Then you would clean the pipe good with sandpaper and then maybe emery cloth and get it nice and shiny clean. Then you can just push on the new valve.
Thanks for both answers, I was a bit concerned I didn't have enough pipe below the T for a Sharkbite. I've done copper pipe soldering for air lines in the garage, this is a really tight spot with the dishwasher and disposal so I'll give the Sharkbite approach a try.
No need to cut above the saddle tee. The saddle only punctures a hole in the center.
Turn the water off. Remove the saddle valve and cut the pipe just above the puncture.
Sand the pipe and deburr well.
You'll have plenty of pipe for a sharkbite fitting.
You may not be able to remove that fitting in the future due to its close proximity to the tee.
So the install went pretty well, had just enough pipe to get the Sharkbite on the required 15/16". I recut the brass water line and used the new compression sleeve but am getting a very slow leak (one or two drips an hour). It's as tight as I dare go, can I take it apart and reseat the sleeve or do I need to get a new one? Any other tips for avoiding a dribble?
Watch it for a couple of days. The drip may stop. If not you should try to tighten it a bit more. Did you use two wrenches. You need to hold the valve body with one and use the other on the nut. Use opposite pressure on the wrenches to tighten.
You could unscrew the nut and add a small bit of joint compound to the threads.
It will act as a sealant and a lubricant.
You need to go pretty tight to seal the compression ring.
In the end if all else fails.... pick up a nut and compression ring and do it again.
Sometimes there is a tiny groove in the pipe that the ring just won't seal to.
Hello! I've heard of using a tank bolt as a better substitute for a toilet flange bolt. I'm wondering if you find this true? It seems to me that with the round tank bolt there would be no worry about it rotating to the narrow side under the flange, like a usual toilet flange might...potentially pulling out when tightened.
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/578x545/tbolts_03ee0140e32daca262e94fc43f734d9653f3104a.jpg[/img]
I have this laundry sink with a small eighth inch hole that I want to repair--preferable water proof, if not then will keep the water level down. It is a brittle in nature sink, acrylic or something. What's best to fill this hole?
[i]Hole is just to the right and above the drain flange.[/i]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/551x661/sink_9ccbc0dba689bd4638546adecc5e263ffee950f1.jpg[/img]
[i]Close up[/i]
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/472x450/sink1_e0d00dae02761ec0522bb3ff55526a9091364b0b.jpg[/img]
