Connecting new PVC tub drain into existing iron pipe
Hello,
I am replacing my tub drain with a new PVC set. The PVC drain needs to connect to an existing iron nipple. The iron nipple is male threaded. Right now I'm using a plastic slip nut and compression washer.
I've got it all hooked up and have been testing. The only time it leaks is when the tub is full and is draining. The leak point is at the connection of the PVC to the iron. It does not leak when water is flowing continuously and the tub is not full.
What can be done to fix this? Should I change how I try to connect? Is it just a matter of ensuring my current connection is aligned correctly?
Reason: The iron pipe I need to connect to is a nipple. I didn't know the terminology before posting.
I have this laundry sink with a small eighth inch hole that I want to repair--preferable water proof, if not then will keep the water level down. It is a brittle in nature sink, acrylic or something. What's best to fill this hole?
[i]Hole is just to the right and above the drain flange.[/i]
[img]https://cimg2.ibsrv.net/gimg/www.doityourselft.com-vbulletin/551x661/sink_9ccbc0dba689bd4638546adecc5e263ffee950f1.jpg[/img]
[i]Close up[/i]
[img]https://cimg5.ibsrv.net/gimg/www.doityourselft.com-vbulletin/472x450/sink1_e0d00dae02761ec0522bb3ff55526a9091364b0b.jpg[/img]
Toilet is currently filled as normal (i.e. it hasn't been flushed since water to house was turned off due to maintenance work in the area), so I assume it's ok to flush, it just won't fill back up, correct?
And even if it perhaps shouldn't be flushed, but already has been (as my son just flushed already...) is there anything I should do/be aware of, or will it just fill back up once the water comes on again?
Thank you.
