new disposal, "quiet collar"/sink baffle too tight
I just replaced a 20+ year ols disposal with an Insinkerator Evolution Esteem Plus 1HP Disposal which is amazing, so quiet I initially thought it wasn't working. The only problem is the rubber baffle is so restrictive water barely flows down the drain unless I prop it open with a spatula or something. Ironically the baffle in the old one had worn away to almost nothing. I've tried cutting straight lines on several of the folds but it's still a problem. It pops out easily enough so we'll often just remove it but if we run the disposal without it in place it'll splash straight up. Are there less restrictive designs available? I've considered the Danco "disposal genie" but I'd rather not have yet another single-function gadget in the sink.
I have a similar model and it acts more or less the same. I think the design contributes to how quiet the unit is. I've found that starting the disposal usually creates enough "pull" that the water clears and drains properly. And it will usually start draining once the water gets a little deeper above the baffle, and once it starts flowing, it tends to keep flowing.
yeah, if that were my experience I would not have posted here....
Mine does the same exact thing.
I consider it normal and just push it open it manually if it doesn't prime by itself.
I think it's mostly setup like that to reduce kickback/discharge which I've seen cause damage.
I put the direct link in your first post as your link is to your Ebay account and is private to us.
Check thru the reviews there. See if someone else comments on it.
My toilet water is very low. I turned the hex screwdriver part on the fill valve clockwise several times and flushed the toilet. There was no change in water height. I noticed no water was coming into the refill tube and instead coming out of the fill valve cap on the back top right side. Do I need to replace the fill valve, or is there something I am missing. Thank you!
[img]https://cimg0.ibsrv.net/gimg/www.doityourselft.com-vbulletin/2000x1504/bathroom_d4ebc59d51c845876ae9c3954fd999d59907bad2.jpg[/img]
Persona who installed dishwasher didn't secure the high Loop drain hose under the cabinet what are you guys recommendantions of what to secure this to the MDF cabinet
