Toilet Tank Cracked
Old 06-08-23, 11:36 AM
A
Toilet Tank Cracked
The toilet tank cracked (I have no idea how), I went to replace it, and cannot find the Peerless Pottery brand anywhere - Is there a compatible tank replacement for this make/model?
Old 06-08-23, 12:54 PM
Received 3,593 Upvotes on 3,222 Posts
Welcome to the forums.
Not likely to find just the tank. Replace the entire toilet.
CasualJoe voted this post useful.
Old 06-08-23, 05:21 PM
Received 1,229 Upvotes on 1,178 Posts
Not worth the time or effort - replace the entire unit.
Old 06-09-23, 04:48 AM
P
Received 1,950 Upvotes on 1,746 Posts
Especially with modern low water consumption toilets it is important to match the tank and bowl. They are designed to work together. A modern tank on your older bowl could result in weak flushes and clogs.
Old 06-09-23, 08:28 AM
Z
Received 112 Upvotes on 103 Posts
I cracked my tank in a spectacular feat of creative stupidity and unintended destruction. It is a 1950’s yellow toilet and since that color is long gone replacing the toilet meant redoing a lot of the bathroom (tub, etc.).
By great luck I found a guy selling the exact tank on ebay - and even within driving distance.
I agree you might just replace the whole toilet but if there is some reason you can’t or don’t want to maybe you could check ebay.
Here’s an example of a tank for sale, maybe you could find your exact tank if need be.
WHITE 19.25 x 8.25 3,5 #3 #5 Peerless Rudisill Embry Burden Lathery toilet tank | eBay
Old 06-11-23, 04:40 PM
CasualJoe's Avatar
Received 178 Upvotes on 161 Posts
If cost is an issue I think we can all relate, but I recently was given a tip from a plumber that he was pretty impressed with the Project Source toilets from Lowes. Project Source is their store brand. Anyway, he said he had installed a few and was impressed with them. I normally never recommend store branded faucets or fixtures, but in this case I'll make an exception.
