toilet flow restrictor
Old 07-06-23, 04:02 PM
T
Received 1 Upvote on 1 Post
I have a Y connection on my toilet line that feeds the toilet tank and also a bidet. Something has gone wrong with the bidet flow control and the pressure is unpleasantly high. I can lower it by closing off the toilet valve part way, but that makes the toilet fill slowly (and loudly). Is there such a thing as an in-line valve I can put just on the bidet line to lower the pressure just on that line?
Johntheplumber voted this post useful.
Old 07-06-23, 04:06 PM
XSleeper's Avatar
Received 1,845 Upvotes on 1,660 Posts
I'm sure, but we don't know the size or connection of your current line.
Old 07-06-23, 04:56 PM
P
Received 2,014 Upvotes on 1,806 Posts
I assume you have a Japanese style toilet seat bidet (a European one you'd just open the faucet less). Check the instructions for your bidet. Some can adjust the pressure. On mine it's one of the controls on the remote.
Old 07-06-23, 05:58 PM
T
1/2" FIP/MIP connector
Old 07-06-23, 09:05 PM
XSleeper's Avatar
Put a straight 1/2" FIP/MIP quarter turn valve on where your bidet connects, if your bidet flow control isn't working.
toecheese voted this post useful.
Old 07-07-23, 10:10 AM
T
good idea, thanks
Old 07-13-23, 09:32 AM
Yes, there is such a thing as an in-line valve that you can put just on the bidet line to lower the pressure just on that line. You can use an adjustable T-valve which is an easy way to control the water pressure coming out of the bidet1. Another option is to install an external water filter which can help reduce the water pressure2.
I hope this helps!
Old 07-13-23, 10:17 AM
Norm201's Avatar
Received 703 Upvotes on 625 Posts
The bidet itself should have a flow control lever to control the force of the water. I have two of the least expensive base models and both can control the flow. But I still throttled back the toilet fill valve. Since once I'm done, I'm in no hurry for the tank to refill. However, my toilets do not make very much noise.
